Configure ACE ARP entries
Use ACE Address Resolution Protocol (ARP) entries so that the filter looks for ARP request or response packets.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select a parameter for the appropriate ACL.
- Select ACE.
- Select a parameter for the appropriate ACE.
- Select Arp.
- Select Insert.
- Select ARP request or response.
- Select Insert.
ARP field descriptions
Use the data in the following table to use the ARP tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Type |
Specifies the ACE ARP operation. The only option is operation. |
Oper |
Specifies the operator for the ACE ARP operation. The only option is eq (equal). |
Value |
Specifies the ARP packet type. Valid options are arpRequest and arpResponse. |
