Configure OVSDB Globally
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to configure the OVSDB certificates, private key, and replication global settings.
- Select OVSDB.
- Select the Globals tab.
- Select Enable.
- In the CertificateFilename field, type the filepath/filename.
- In the CertFileInstallAction field, select install.
- Select Apply.
- In the PrivateKeyFilename field, type the filepath/filename.
- In the PrivateKeyInstallAction field, select install.
- Select Apply.
- Select ReplicationEnable.
- In the ReplicationPeerIpAddr field, type the IP address.
- In the ReplicationLocalIpAddr field, type the IP address.
- Select Apply.
- Verify the ReplicationState.
Globals field descriptions
Use the data in the following table to use the Globals tab.
Name |
Description |
Enable |
Enables or disables the feature. Default is disabled (cleared). |
CertificateFilename |
Specifies the filename of the certificate. |
CertFileInstallAction |
Specifies to install or uninstall the certificate. You must have a certificate file on the switch. |
PrivateKeyFilename |
Specifies the filename of the private key. |
PrivateKeyInstallAction |
Specifies to install or uninstall the private key. You must have a private key file on the switch. |
ReplicationEnable |
Enables or disables replication support. Default is disabled (cleared). |
ReplicationPeerIpAddr |
Specifies the replication server peer IP address in A.B.C.D format. |
ReplicationLocalIpAddr |
Specifies the replication local IP address in A.B.C.D format. |
ReplicationState |
Displays the current replication status. |
