This procedure only applies to XA1400 Series.
For XA1400 Series branch deployments, the VOSS routing IP stack requires the VLAN Management Instance to work in coexistence mode where both the management IP stack and the routing IP stack share the same IP address and default routes. This is required for an IPsec source address.
You can manually configure the coexistence or you can use the propagate-to-routing command to propagate the management VLAN IP and static routes from the management IP stack to the VOSS routing IP stack on the same VLAN ID. If you do not include the VRF name, the system uses the existing VRF of the VOSS routing VLAN.
enable
configure terminal
mgmt vlan
propagate-to-routing [vrf WORD<0-16>]
