Change VLAN Port Membership
Modify VLAN port members to control access to the VLAN.
  1. In the navigation tree, expand the following folders: Configuration > VLAN.
  2. Select VLANs.
  3. Select the PortMembers number for the VLAN for which you want to modify port membership.
  4. Select the port members you wish to add or remove.
  5. Select Ok.
  6. Select Apply.
    The VLAN port membership is changed.
