Configure RADIUS SNMP parameters for authentication and session times.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click RADIUS.
  3. Select the RADIUS SNMP tab.
  4. Select the Enable check box to enable RADIUS SNMP.
  5. In the AbortSessionTimer field, enter the period after which the session expires in seconds.
  6. In the ReAuthenticateTimer field, enter the period of time the system waits before reauthenticating in seconds.
  7. Select the AcctEnable check box to enable RADIUS accounting for SNMP.
  8. In the UserName field, type the RADIUS SNMP user name.
  9. Click Apply.
RADIUS SNMP field descriptions
Use the data in the following table to use the RADIUS SNMP tab.
Name
Description
Enable
Enables or disables timer authentication on the server. The default is true.
AbortSessionTImer
Specifies the allowable time, in seconds, before aborting the RADIUS SNMP server session (30 to 65535). The default is 180.
ReAuthenticateTimer
Specifies the time, in seconds, between reauthentications of the RADIUS SNMP server (30 to 65535). The default is 180.
AcctEnable
Enables or disables the RADIUS SNMP session timer.
UserName
Specifies the user name for the RADIUS SNMP accounting.
