Use the following procedure to configure MLD parameters for the switch.
- In the navigation pane, expand folders.
- Click IPv6 MLD.
- Click the Globals tab.
- Configure the MLD global parameters as required.
- On the toolbar, click Apply to save the changes.
- On the toolbar, click Refresh to update the changes.
Globals field description
Use the data in the following table to use the Globals tab.
Field |
Description |
GenerateTrap |
Enables MLD to generate traps. |
GenerateLog |
Enables MLD to generate logs. |
