  • Enable multicast on the boundary nodes.
  • Configure Multiprotocol Label Switching Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
  • Configure the same policies as the boundary node on the peer boundary nodes.
Perform this procedure to configure Multi-area SPB IPv4 routed multicast redistribution on the switch.
  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Create the Multi-area SPB IPv4 routed multicast redistribution instance:
    multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home]
    If you do not specify the direction for redistribution then the system applies the redistribution in both directions by default.
  3. Optional: Configure a route policy to govern the redistribution:
    multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home] route-map WORD<1-64>
  4. Enable the Multi-area SPB IPv4 routed multicast redistribution instance:
    multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home] enable
  5. Verify the Multi-area SPB IPv4 routed multicast redistribution configuration:
    show isis multi-area ip redistribute routed-multicast [home-to-remote | remote-to-home]
  6. Apply the Multi-area SPB IPv4 routed multicast redistribution:
    isis multi-area ip apply redistribute routed-multicast [home-to-remote | remote-to-home]
Configuring Multi-area SPB IPv4 routed multicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote route-map test
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote enable
Switch:1(config-isis)#show isis multi-area ip redistribute routed-multicast home-to-remote
      ISIS Multiarea Redistribute List for routed multicast - GlobalRouter
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(config-isis)#isis multi-area ip apply redistribute routed-multicast home-to-remote
The following table defines parameters for the multi-area ip redistribute routed-multicast and the isis multi-area ip apply redistribute routed-multicast command.
Variable Value
enable
Enables Multi-area SPB IPv4 routed multicast redistribution.
home-to-remote
Specifies the IPv4 routed multicast redistribution configuration for home to remote direction.
remote-to-home
Specifies the IPv4 routed multicast redistribution configuration for remote to home direction.
Specifies the name of the route policy.
vrf WORD<1-16>
Specifies the multicast routing redistribution configuration for specific VRF instance.
