Perform this procedure to configure a scheduled time interval during which the switch will operate in low power state. This time interval can be for a week, weekend, or individual days.
You can configure maximum 84 entries in the Energy Saver schedule.
If efficiency mode is enabled, you cannot configure any other entries in theEnergy Saver schedule.
You must disable Energy Saver globally.
You must enable Energy Saver on every port affected by the schedule.
You must deactivate Energy Saver efficiency-mode.
- Click Energy Saver.
- Click the Energy Saver Schedules tab.
- Click Insert.
- Configure the fields as required.
- Click Insert.
- Click Apply.
Energy Saver Schedules Field Descriptions
Name |
Description |
ScheduleDay |
Specifies the day on which Energy Saver is activated or deactivated. The options are:
ScheduleHour |
Specifies the hour at which Energy Saver is activated or deactivated. The range is 0 to 23. Note:
0 is equivalent to 12 a.m., and 12 is equivalent to 12 p.m. |
ScheduleMinute |
Specifies the minute at which Energy Saver is activated or deactivated. The range is 0 to 59. |
ScheduleAction |
Specifies if Energy Saver is activated or deactivated. The options are:
