This procedure only applies to XA1400 Series.
Use the following procedure to retrieve the tunnel CoS queue statistics. The system opens the statistics of the forwarded packets and bytes and the dropped packets and bytes.
- In the navigation tree, expand: .
- Select CoS Queue Stats.
- Select the Tunnel tab.
Tunnel Field Descriptions
The following table describes the fields from the CoS Queue Stats Tunnel tab.
Name |
Description |
Index |
Indicates the loopback port number from 192(1/1) to 241(1/50). |
Que<0–7>OutPackets |
Indicates the out packets by CoS queue number 0–7. |
Que<0–7>OutBytes |
Indicates the out bytes by CoS queue number 0–7. |
Que<0–7>DropPackets |
Indicates the drop packets by CoS queue number 0–7. |
Que<0–7>DropBytes |
Indicates the drop bytes by CoS queue number 0–7. |
