After you have configured the SPBM infrastructure, you can enable SPBM Layer 3 Virtual Services Network (VSN) to advertise IPv6 routes across the SPBM network from one VRF to another using the following procedure.
SPBM Layer 3 VSN uses IS-IS to exchange the routing information for each VRF.
You must enable IPv6 Shortcuts.
You must configure the required SPBM IS-IS infrastructure.
You must configure a VRF and IPv6 VPN instance on the switch. For more information, see VRF Lite configuration using Enterprise Device Manager.
A new browser tab opens containing the selected VRF view
