This procedure does not apply to XA1400 Series and VSP 8600 Series.
  • Configure Multicast Label Switching Virtual Private Network (MVPN) on VRF.
  • Enable IP Multicast over Fabric Connect globally.
  • Configure IP prefix list in GRT/VRF.
Perform this procedure to create the IP SPB Multicast Policy globally.
  • You can also configure the IP SPB Multicast Policy on a VRF instance in the same way as you configure on the GlobalRouter, except that you must use the VRF Router Configuration mode and create the route-map in VRF Router Configuration mode. Not all parameters are configurable on non0 VRFs.
  • This configuration does not apply to IGMP snooping and DvR Leaf.
  • Multi-area SPB boundary nodes with remote IS-IS enabled do not support IP SPB Multicast Policy .
  1. Enter Route-Map Configuration mode:
    enable
    configure terminal
    route-map WORD<1-64> <1-65535>
  2. Enable the route policy:
    enable
  3. Match the IP SPB Multicast Policy to the multicast group:
    match multicast-group WORD<0-259>
  4. Optional: Set the data flow for the IP SPB Multicast Policy :
    set {rx-only | tx-only}
  5. Configure the data I-SID:
    set data-isid <1-15999999>
  6. Permit the route:
    permit
  7. Exit to Global Configuration mode:
    exit
  8. Associate the IP SPB Multicast Policy with the route-map:
    ip spb-multicast-policy route-map WORD<0-64>
  9. Enable the IP SPB Multicast Policy :
    ip spb-multicast-policy enable
  10. Verify the configuration:
    show ip spb-multicast-policy
  11. Apply the IP SPB Multicast Policy instance:
    ip spb-multicast-policy apply
Creating an IP SPB Multicast Policy globally.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#route-map rtest 210
Switch:1(route-map)#enable
Switch:1(route-map)#match multicast-group McastGroup
Switch:1(route-map)#set data-isid 210
Switch:1(route-map)#permit
Switch:1(route-map)#exit
Switch:1(config)#ip spb-multicast-policy route-map rtest
Switch:1(route-map)#ip spb-multicast-policy enable
Switch:1(config)#show ip spb-multicast-policy
            SPB ROUTED IP MULTICAST POLICY - GlobalRouter
ENABLE     RPOLICY
TRUE       rtest
Switch:1(route-map)#ip spb-multicast-policy apply
Creating an IP SPB Multicast Policy on VRF1.
Switch:1>enable
Switch:1(config)#router vrf VRF1
Switch:1(router-vrf)#route-map rtest 210
Switch:1(router-vrf-routemap)#enable
Switch:1(router-vrf-routemap)#match multicast-group McastGroup
Switch:1(router-vrf-routemap)#set data i-sid 5679
Switch:1(router-vrf-routemap)#permit
Switch:1(router-vrf-routemap)#exit
Switch:1(router-vrf)#ip spb-multicast-policy route-map rtest
Switch:1(router-vrf)#ip spb-multicast-policy enable
Switch:1(router-vrf)#exit
Switch:1(config)#show ip spb-multicast-policy vrf VRF1
            SPB ROUTED IP MULTICAST POLICY - VRF VRF1
ENABLE    RPOLICY
TRUE        rtest
Switch:1(config)#ip spb-multicast-policy apply vrf VRF1
