Enables you to configure SPB and IS-IS, but you cannot configure PIM and IGMP, either globally or on an interface.
Use the no operator if you need to configure PIM and IGMP.
The boot flag is enabled by default.
    enable
    configure terminal
  2. Enable SPBM and IS-IS configuration:
    boot config flags spbm-config-mode
  3. Save the changed configuration.
  4. Restart the switch.
