Use the following procedure to view the IKE Phase 1 security association.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click IKE.
  3. Click the SA tab.
IKE SA field descriptions
Use the data in the following table to use the IKE > SA tab.
Name
Description
Id
Specifies the profile ID.
LocalIfIndex
Specifies the Interface Index of the local address. Only port and vlan interfaces are supported.
LocalAddrType
Specifies whether the local address is an IPv4 or IPv6 address.
LocalAddr
Specifies the address of the local peer.
RemoteAddrType
Specifies whether the remote address is an IPv4 or IPv6 address.
RemoteAddr
Specifies the address of the remote peer.
Name
Specifies the name given to the SA.
AuthenticationMethod
Specifies the proposed authentication method for the Phase 1 security association.
The default authentication method is pre-shared key.
DPDTimeout
Specifies the Dead Peer Detection timeout in seconds.
HashAlgorithm
Specifies the hash algorithm negotiated for this IKE Phase 1 SA.
EncryptionAlgorithm
Specifies the encryption algorithm negotiated for this IKE Phase 1 SA.
EncryptKeyLen
Specifies the encryption key length negotiated for this IKE Phase 1 SA.
DHGroup
Specifies the Diffie-Hellman group negotiated for this IKE Phase 1 SA.
ExchangeMode
Specifies the IKE Phase 1 SA mode.
LifetimeSeconds
Specifies the amount of time for which an IKE Phase 1 SA can remain valid during IKE Phase 1 negotiation. A value of 0 means no the SA always remains valid.
Status
Specifies whether the SA is active or inactive.
Initiator
Specifies whether specifies the whether the SA is created by an initiator or a responder.
