Perform this procedure to display the Auto-sense configuration on the switch.
show auto-sense [access-differv] [data] [dhcp-detection] [eapol] [fa] [isis] [onboarding] [qos] [voice] [wait-interval]
show interfaces gigabitEthernet auto-sense [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Display the Auto-sense configuration related to voice:
Switch:1>show auto-sense voice
AUTO-SENSE VOICE Config
TYPE LDDP-AUTH ENABLE I-SID C-VID DSCP PRIORITY
phone FALSE 2000 2000 46 6
1 out of 1 Total Num of AUTO-SENSE entries displayed
Display the Auto-sense status and state on a range of ports:
Switch:1>enable
Switch:1#show interfaces gigabitethernet auto-sense 1/1-1/5
Port Auto-sense
PORT AUTO-SENSE AUTO-SENSE AUTO-SENSE AUTO-SENSE
NUM STATUS STATE PORT-DATA-ISID PORT-WAIT-INTERVAL
1/1 Enable DOWN -- 20
1/2 Enable DOWN -- 10
1/3 Enable DOWN -- 10
1/4 Enable DOWN -- 10
1/5 Disable OFF -- 10
Display the Auto-sense status for Fabric Attach (FA):
Switch:1>show auto-sense fa
AUTO-SENSE FA Config
MSG-AUTH MSG-AUTH-KEY
enabled ****
AUTO-SENSE FA Client specific config
TYPE EAPOL STATUS I-SID VLANID C-VID MGMT I-SID MGMT C-VID
camera Auto 100 100 untag - -
wap-type1 Auto 200 200 untag - -
open-virtual-switch Auto - - - - -
proxy-no-auth Auth 300 300 untag - -
proxy Auth 400 n/a 400 400 400
6 out of 6 Total Num of AUTO-SENSE entries displayed
Display the global Auto-sense wait-interval information:
Switch:1>show auto-sense wait-interval
AUTO-SENSE GLOBAL Config
WAIT
INTERVAL
50
0 out of 0 Total Num of AUTO-SENSE entries displayed
