Perform this procedure to view the MACsec statistics.
enable
show macsec statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
show macsec statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}] secure-channel inbound
show macsec statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}] secure-channel outbound
Display general MACsec statistics, inbound MACsec statistics, and outbound MACsec statistics:
The switch supports MACsec on specific ports. For more information, see your hardware documentation.
Display inconsistencies might occur for MACsec statistics when different ports interoperate with one another.
The VSP4900-24P and VSP 8404 display only the Security Association (SA) statistics and not the global Secure Channel statistics. If you shutdown a port on these switches and it has MACsec enabled, then the system deletes the SAs and displays the count as 0 in the show commands.
Switch:1>enable
Switch:1#show macsec statistics 1/40
MACSEC Port Statistics
TxUntagged TxTooLong RxUntagged RxNoTag
PortId Packets Packets Packets Packets
1/40 0 0 0 0
RxBadTag RxUnknown RxNoSCI RxOverrun
PortId Packets SCIPackets Packets Packets
1/40 0 0 0 0
Switch:1#show macsec statistics 1/40 secure-channel inbound
MACSEC Port Inbound Secure Channel Statistics
UnusedSA NoUsingSA Late NotValid Invalid
PortId Packets Packets Packets Packets Packets
1/40 0 0 0 100037 0
Delayed Unchecked Ok Octets Octets
PortId Packets Packets Pkts Validated Decrypted
1/40 0 0 0 53528828 0
Switch:1#show macsec statistics 1/40 secure-channel outbound
MACSEC Port Outbound Secure Channel Statistics
Protected Encrypted Octets Octets
PortId Packets Packets Protected Encrypted
1/40 0 99946 0 53434154
