View the AS-scope link-state database (LSDB) to see the LSAs that are flooded through the routing domain. The AS scope is used for AS external-LSAs.
  • Change the VRF instance as required to view OSPFv3 on a specific VRF instance.
  1. In the navigation tree, expand the following folders: Configuration > IPv6.
  2. Click OSPFv3.
  3. Click the AS-scope LSDB tab.
AS-scope LSDB field descriptions
Use the data in the following table to use the AS-scope LSDB tab.
Name
Description
Type
Shows the type of the link-state advertisement. Each link state type has a separate advertisement format. AS-scope LSAs not recognized by the router may be stored in the database.
RouterId
Shows the 32 bit number that uniquely identifies the originating router in the autonomous system.
Lsid
Identifies the piece of the routing domain that is being described by the advertisement.
Sequence
Shows a signed 32-bit integer that detects old and duplicate link-state advertisements. The larger the sequence number, the more recent the advertisement.
Age
Shows the age of the link-state advertisement in seconds.
Checksum
Indicates the checksum of the complete contents of the advertisement, except the age field. The age field is not affected so that the advertisement age value increments without updating the checksum. The checksum used is the same for ISO connectionless datagrams, the Fletcher checksum.
