Feature |
Product |
Release introduced |
IS-IS hello padding (ability to disable) |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.4.2 |
5520 Series |
VOSS 8.2.7 |
5720 Series |
Fabric Engine 8.7 |
7520 Series |
Fabric Engine 8.10 |
7720 Series |
VSP 4450 Series |
VOSS 8.2.7 |
VSP 4900 Series |
VOSS 8.2.7 |
VSP 7200 Series |
VOSS 8.2.7 |
VSP 7400 Series |
VOSS 8.2.7 |
VSP 8200 Series |
VOSS 8.2.7 |
VSP 8400 Series |
VOSS 8.2.7 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
VOSS 8.2.7 |
To detect maximum transmission unit (MTU) mismatches, Intermediate System-to-Intermediate System (IS-IS) pads hello packets to the full interface MTU. All hello packets on Fabric Extend network-to-network interface (NNI) links are padded . On non-Fabric Extend point-to-point NNI links, hello packets are padded until a hello packet is received from the other side.
If you downgrade to a release that does not support this feature, you must disable the feature and save the configuration before you downgrade. You must have a compatible configuration file if you downgrade to an earlier release.
