This section provides details to configure PoE settings using CLI.
Important
After you enable Fast PoE or Perpetual PoE or both, you must save the running configuration file.
If Fast PoE or Perpetual PoE are enabled and you change any other global or port-specific PoE settings, you must resave the running configuration file.
