Configure keepalive messages to adjust the interval in seconds at which an MSDP peer sends keep
alive messages (default is 60 seconds) and the interval at which the MSDP peer waits for
keep alive messages from other peers before it declares them down (default is 75 seconds).
In a peer relationship, the keep alive interval configured on one peer must be at least 1 second less than the hold time configured on the other side of the peer relationship. This is not applicable when the hold time is set to 0 seconds.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp keepalive 21.0.0.2 70 71
Variable definitions
The following table defines parameters for the ip msdp keepalive command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
<0-21845> |
Specifies the keep alive interval in seconds. The default is 60 seconds. |
<0-65535> |
Specifies the hold time interval in seconds. The default is 75 seconds.
Note:
0 seconds means the peer never expires. Values 1 and 2 are not allowed. |
