Perform the following procedure to view the power consumption of the modules in the chassis.
- Click Chassis.
- Click the Power Consumption tab.
Power consumption field descriptions
Use the data in the following table to use the Power Consumption tab.
Name |
Description |
Index |
Displays an index value that identifies the component. |
PowerStatus |
Displays the power status: on or off. |
BasePower |
Displays the base power required for the slot. |
ConsumedPower |
Displays the actual consumed power for the slot. This value is 0 if the power status is off. |
PowerPriority |
Displays the priority of the slot for power management. |
SlotDescription |
Displays the slot number. |
CardDescription |
Identifies the type of module in the slot. |
