You must first onboard the device and configure any optional IQ Agent parameters before you enable IQ Agent.
  1. In the navigation pane, expand Configuration > Serviceability.
  2. Select IQAgent.
  3. Select the Globals tab.
  4. Configure optional parameters as required.
  5. Select Apply.
  6. Select Enable.
  7. Select Apply.
Use the data in the following table to use the Global tab to configure the ExtremeCloud IQ Agent.
Name
Description
Enable
Specifies whether IQ Agent is enabled. The default is enabled.
Version
Displays the ExtremeCloud IQ Agent firmware version running on the switch.
OperStatus
Displays the operational status of ExtremeCloud IQ Agent on the switch.
ServerAddressType
Specifies the address type of the ExtremeCloud IQ server address.
ServerAddress
Specifies the ExtremeCloud IQ IPv4 address or DNS name.
The default is hac.extremcloudiq.com.
ServerAddressOrigin
Specifies the origin for the ExtremeCloud IQ server address:
  • none–not configured
  • configured–manual configuration
  • dhcp–obtained through DHCP
Address
Specifies the proxy IPv4 address or DNS name.
TcpPort
Specifies the TCP connection port.
UserName
Specifies the proxy server password.
Password
Specifies the proxy server username.
AssociationUrl
Displays the association URL of ExtremeCloud IQ.
PollUrl
Displays the poll URL of ExtremeCloud IQ.
MonitorFreq
Displays the monitoring frequency, in seconds, of ExtremeCloud IQ.
PollFreq
Displays the polling frequency, in seconds, of ExtremeCloud IQ.
LastOnboardTime
Displays the last onboard time of ExtremeCloud IQ.
LastPollStatus
Displays the last poll status of ExtremeCloud IQ.
LastPollTime
Displays the last poll time for a successful attempt.
LastMonitorStatus
Displays the last monitoring status of ExtremeCloud IQ.
LastMonitorTime
Displays the last monitor time for a successful attempt.
LastHealthStatus
Displays the last health status of ExtremeCloud IQ.
LastHealthTime
Displays the last health time for a successful attempt.
LastDisconnectedTime
Shows when IQ Agent disconnected from ExtremeCloud IQ.
This status is not valid unless IQ Agent is enabled and in a disconnected state.
LastAttemptedAssociationTime
Shows the last time IQ Agent attempted to associate with ExtremeCloud IQ.
NextAssociationAttempt
Shows the next time IQ Agent will attempt to associate with ExtremeCloud IQ. This field displays In progress if IQ Agent is currently attempting to associate.
AssociationFrequencyMode
Shows the frequency at which IQ Agent attempts to associate with ExtremeCloud IQ. Fast mode indicates an attempt every 40 seconds. Slow mode indicates an attempt every hour. For the first 24 hours of disconnection, the mode is Fast mode. The mode then changes to slow and remains in slow mode until successfully connected.
When you first onboard a device to ExtremeCloud IQ, it does not connect to the device immediately; it waits until the device attempts association again, which can take up to 1 hour.
