This procedure only applies to VSP 8400 Series.
The following example displays MACsec MKA statistics for a port.
Switch:1>show macsec mka statistics 3/5 ========================================================================================== MKPDU Statistics on interface 3/5 ========================================================================================== MKPDUs Validated & Rx : 1630 Rx Distributed SAK : 2 MKPDUs Transmitted : 1694 Tx Distributed SAK : 0 ------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------
Use the data in the following table to use the show macsec mka statistics command.
Variable | Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
