This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to associate an Extreme Integrated Application Hosting (IAH) port to a Virtual Router Forwarding (VRF) instance.
You can associate a VRF instance to an IAH port after you configure the VRF. By default, the IAH ports are associated to the GlobalRouter.
- In the navigation pane, expand the following folders: .
- Select the IAH port you want to configure.
- Select the VRF tab.
- Optional: In the VrfNames field, select the ShowAll button to view the VRF instances the IAH Port is associated with.
- In the BrouterVrfId field, select the ellipsis (...) button, and select the required VRF instance(s).
- Select Ok.
- Select Apply.
VRF Field Descriptions
Use data in the following table to use the VRF tab.
Name |
Description |
VrfIds |
Shows the VRF ID. |
VrfNames |
Shows the VRF name. |
VrfCount |
Shows the number of VRFs to which the Extreme Integrated Application Hosting (IAH) port is associated with. |
BrouterVrfId |
Specifies the VRF ID for a brouter port. |
BrouterVrfName |
Shows the VRF name for a brouter port. |
