This procedure does not apply to VSP 4450 Series or XA1400 Series.
Perform this procedure to enable Link Layer Discovery Protocol (LLDP) voice authentication of IP phones on a port.
You cannot manually enable LLDP voice authentication on an Auto-sense-enabled port. If the system detects a phone on an Auto-sense port, then “eapol voice lldp-auth” configuration is automatically applied on the port that connects to the phone. This procedure applies to ports with Auto-sense disabled.
Enabling LLDP voice authentication on a specific port:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#eapol voice lldp-auth
The following table defines parameters for the eapol voice command.
Variable |
Value |
lldp-auth |
Enables Link Layer Discovery Protocol (LLDP) voice authentication of IP phones on the selected port. By default, LLDP authentication of IP phones is disabled on the switch. |
