This procedure only applies to VSP 4450 Series.
View port routing statistics to manage network performance.
- In the Device Physical View, select a port.
- In the navigation tree, expand .
- Select Port.
- Select the Routing tab.
Routing Field Descriptions
Use the data in the following table to use the Routing tab.
Name |
Description |
InUnicastFrames |
The number of incoming unicast frames routed. |
InMulticastFrames |
The number of incoming multicast frames routed. |
InDiscards |
The number of frames discarded by the routing entity. |
OutUnicastFrames |
The number of outgoing unicast frames routed. |
OutMulticastFrames |
The number of outgoing multicast frames routed. |
