- In ExtremeCloud IQ - Site Engine, configure your third-party virtualization platform, and the RADIUS server used for Endpoint Tracking authentication. For information about configuring ExtremeCloud IQ - Site Engine, see the ExtremeCloud IQ - Site Engine documentation at https://www.extremenetworks.com/support/documentation/.
On the switch, add and configure the RADIUS server as configured in ExtremeCloud IQ - Site Engine.
Enable Endpoint Tracking on ports or MLT/SMLT interfaces.
- Select Endpoint Tracking.
- Select the Interface tab.
- Select Insert.
- Select Port or Mlt, select the slot and port number or MLT ID, and select OK.
- Select InterfaceEnable.
- Select Insert.
- Select Apply.
What to do next
Next, configure Endpoint Tracking globally on the switch.
Interface Field Descriptions
Use the data in the following table to use the Interfaces tab.
| Name | Description |
InterfaceIndex |
Specifies the interface index of the selected port or MLT. |
InterfaceEnable |
Enables Endpoint Tracking on the selected port or MLT. |
