View the DvR routes (IPv4 network routes) on a DvR Controller or a Leaf node.
Controllers display all the IP subnet routes configured for that DvR domain. The Leaf nodes display the IP subnet routes that are learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. Leaf nodes also display routes that are redistributed by Controllers (direct routes, static routes and the default route), into the DvR domain.
Ensure that you enable DvR globally on the node.
  1. Enter Privileged EXEC mode:
    enable
  2. View the DvR routes.
    On a Controller:
    show dvr routes [ipv4 {A.B.C.D}]|[l3isid <0-16777215>]|[nh-as-mac]|[vrf WORD<1-16>]|[vrfids WORD<0-512>]
    On a Leaf node:
    Viewing the DvR routes for a specific VRF or VRF ID is not supported on a DvR Leaf node.
View DvR routes on either a Controller or a Leaf node.
Switch:1#show dvr routes
                                                            DVR Routes
                                     NEXT                                     L3VSN         L2VSN
DEST            MASK                 HOP                              VRFID    ISID          ISID        TYPE      COST
50.0.0.0        255.255.0.0          Ctrl-1:8400:121                  0        55500        50500        -         1
1 out of 1 Total Num of DVR Routes displayed
TYPE Legend:  E=Ecmp Route
View DvR routes where the next hop MAC address is displayed instead of the system name:
Switch:1#show dvr routes nh-as-mac
                                                            DVR Routes
                                     NEXT                                     L3VSN         L2VSN
50.0.0.0        255.255.0.0          00:bb:00:00:01:02                0       55500         50500        -         1
Variable definitions
Use the data in the following table to use the show dvr routes command.
Variable
Value
ipv4 {A.B.C.D}
Specifies the IP address (IPv4) of the DvR route.
l3isid <0-16777215>
Specifies the Layer 3 I-SID of the DvR route.
The range is 0 to 16777215.
nh-as-mac
Specifies the MAC address of the next hop node instead of the system name.
vrf
Specifies the VRF name of the DvR route.
vrfids
Specifies the VRF ID of the DvR route.
The range is 0 to 512.
