Display information about BGPv6 redistributed routes.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about BGPv6 redistributed routes:
    show bgp ipv6 redistributed-routes [vrf <WORD 1-16] [vrfids <0-255>]
The following table defines parameters for the show bgp ipv6 redistributed-routes command.
Variable
Value
vrf
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids
Specifies a range of VRFs by ID number (the ID ranges from 0–255).
