![Note](images/note.png)
This procedure does not apply to XA1400 Series.
Configure broadcast/unknown unicast and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
VSP 8600 Series does not support this feature for unknown unicast traffic.
The following table defines parameters for the rate-limit command.
Variable |
Value |
{<1-65535> | <50-65000000>} |
Specifies the bandwidth limit for broadcast/unknown unicast and multicast traffic, in packets per second (pps). Note:
The <50-65000000> range only applies to VSP 8600 Series. |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
