Configure OVSDB Managed Interface
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to configure a I-SID interface for the OVSDB.
- Select OSVDB.
- Select the Interface tab.
- Select Insert.
- In the Isid field, type the I-SID identifier.
- Select Insert.
Interface field descriptions
Use the data in the following table to use the Interface tab.
Name |
Description |
Isid |
Specifies an I-SID to use as the managed interface. |
