Use the following procedure to display information about IPFIX flows. You can display information for all IPFIX flows, or you can specify a single IPFIX flow and display additional information about that flow.
Display all IPFIX flows:
Switch:1>show ip ipfix flows ========================================================================================== IPFIX Flows ========================================================================================== Source Destination Source Destination Protocol In IP IP Port Port Port ------------------------------------------------------------------------------------------ 192.0.2.1 198.51.100.1 63 63 UDP 1/17 203.0.113.2 203.0.113.1 63 63 UDP RX-NNI
Display information about a specific IPFIX flow:
Switch:1>#show ip ipfix flows source-addr 203.0.113.2 dest-addr 203.0.113.1 s 63 d 63 p udp in-port rx-nni ========================================================================================== IPFIX Flows ========================================================================================== Source IP/ Src Port/ Protocol/ Start Time/ Byte Count/ Destination IP Dest Port In Port Observation Time Packet Count ------------------------------------------------------------------------------------------ 203.0.113.2 63 UDP Tue Apr 09 06:48:57 2019 UTC 352376 203.0.113.1 63 RX-NNI Tue Apr 09 06:49:49 2019 UTC 5182
The following table defines parameters for the show ip ipfix flows command.
Variable |
Value |
dest-addr {A.B.C.D} |
Specifies an IP address for the flow destination. |
dest-port <1-65535> |
Specifies a value for the destination port. |
in-port <rx-nni | {slot/port[/sub-port]}> |
Specifies the port that learns the flow. |
protocol {udp|tcp} |
Specifies the transport protocol. |
source-addr {A.B.C.D} |
Specifies an IP address for the flow source. |
source-port <1-65535> |
Specifies a value for the source port. |
