This feature only applies to platforms that have an Open Networking Adapter (ONA) connected to it.
Use the following command to display the current status of the Fabric Extend ONA, which includes release information.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the ONA status:
    show khi fe-ona status
The following output displays the show khi fe-ona status when the ONA is operating normally.
Switch:1#show khi fe-ona status
               ONA STATUS
ONA Device Status : UP
Running Release Name : v1.0.0.0int006-3-g9749735-dirty
Last Image Upgrade Status : UPGRADE_SUCCESS
Last Image File Used For Upgrde: gdb-secure_ona.tgz
The following examples display the output when communication from the switch to the ONA is disrupted. Note that the ONA Down reason lists the cause of the failure. The reason changes depending on the context of the failure.
The following output displays when the configuration push from the switch to the ONA fails:
               ONA STATUS
ONA Device Status : DOWN
ONA DOWN reason : ONA_CONFIG_DOWNLOAD_FAILED
Image Upgrade Status : UNKNOWN
The following output displays when the port connecting to the ONA device port is DOWN:
               ONA STATUS
ONA DOWN reason : ONA_DEVICE_PORT_DOWN
Image File Is Being Used For Upgrade :
The following output displays when the switch is not receiving LLDP packets from the ONA:
               ONA STATUS
ONA DOWN reason : ONA_LLDP_TIMEOUT
On the switch console, the following log message precedes all three of the above cases:
CP1  [03/22/71 09:30:15.336:UTC] 0x00378601 00000000 GlobalRouter ONA WARNING ONA device status detected down
