Configure an untagged default VLAN on a tagged port to separate untagged packets originating from a PC from the tagged packets originating from an IP phone.
  1. In the Device Physical View tab, select a port.
  2. In the navigation tree, expand the following folders: Configuration > Edit > Port.
  3. Select General.
  4. Select the VLAN tab.
  5. Select UntagDefaultVlan.
  6. In the DefaultVlanId, enter a default VLAN ID.
  7. Select Apply.
  8. Select Close.
