Perform this procedure to view location information of remote LLDP-MED on specific ports.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Click Port MED.
  3. Click the Neighbor Location tab.
Neighbor Location Field Descriptions
Name
Description
TimeMark
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021.
LocalPortNum
Specifies the port on which the remote LLDP-MED information is received.
Index
Specifies the particular connection instance that is unique to the remote LLDP-MED.
LocationSubType
Specifies the subtype of the remote LLDP-MED location:
  • coordinateBased
  • civicAddress
  • elin
LocationInfo
Specifies the location information of the remote LLDP-MED.
