Use the following procedure to view IPv6 Mroute route information.
  1. In the navigation pane, expand the following folders: Configuration > IPv6.
  2. Click IPv6 Mroute.
  3. Click the Route tab.
IPv6 Multicast Route field descriptions
Use the data in the following table to use the Route tab.
Name
Description
Group
Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface.
Source
Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface.
SourceMask
Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface.
UpStreamNeighbor
Shows the address of the upstream neighbor from which the IPv6 datagrams from these sources are received.
IfIndex
Displays the slot and port number or VLAN ID for this entry.
ExpiryTime
Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging.
Protocol
Displays the protocol as one of the following:
  • other(1): none of the following
  • local(2): manually configured
  • netmgmt(3): configured by a network management protocol
  • pimSparseMode(8): PIM-SMv2
  • igmpOnly(10)
  • pimSsmMode(11)
  • spb
