Perform this procedure to configure remote Shortest Path Bridging MAC (SPBM) on an interface.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the Interfaces tab.
  4. Select the SPBM button.
  5. Select Insert
  6. Configure the interfaces SPBM parameters.
  7. Select Insert.
SPBM Field Descriptions
Use data in the following table to use the Interfaces SPBM tab.
Name
Description
Index
Specifies an Index value for the remote SPBM interface.
SpbmId
Specifies the remote SPBM ID.
State
Specifies whether the remote SPBM interface is enabled or disabled.
Type
Configures the remote SPBM instance interface-type on the IS-IS interface on the specific port or MLT, the values are point-to-point (ptpt) or broadcast (bcast). The system supports the ptpt interface type only.
L1Metric
Configures the remote SPBM instance l1-metric on the IS-IS interface on the specific port or MLT. The default value is 10.
Origin
Specifies the source of the remote SPBM instance configuration.
  • config - configure manually through CLI or EDM.
  • dynamic - configure dynamically through Auto-sense.
