Displays the IS-IS logical interface IPsec ID and authentication keys.
Use the following procedure to display the IS-IS logical interface IPsec ID and authentication keys.
show isis logical-interface ipsec
Switch:1>show isis logical-interface ipsec ======================================================================================================================================= ISIS Logical Interface IPSec ======================================================================================================================================= ID Status Auth-Method Auth-Key ESP Responder-Only Remote NAT IP Auth-Key-Len Compression Frag-before-encrypt --------------------------------------------------------------------------------------------------------------------------------------- 1 Enable RSA-SIG ****** aes128gcm16-sha256 False - 128 False True --------------------------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces --------------------------------------------------------------------------------------------------------------------------------------- ====================================================================================================================== IPSec Tunnel General Info ====================================================================================================================== IPSec tunnel global source-ip-address : 203.0.113.1 ====================================================================================================================== ISIS IPSec Tunnels ====================================================================================================================== ID IPSec source IP IPSec Dst Ip TUNNEL_NEXT_HOP type address PORT/MLT VLAN VRF ---------------------------------------------------------------------------------------------------------------------- 1 global 203.0.113.1 100.100.100.6 Port1/6 100 GlobalRouter ---------------------------------------------------------------------------------------------------------------------- 1 out of 1 Total Num of Logical ISIS interfaces ----------------------------------------------------------------------------------------------------------------------
