Use the following procedure to display IPsec security association information.
Display information on IPsec security association policies:
Switch:1>enable Switch:1#show ipsec sa all ========================================================================= IPSEC Security Association Table ========================================================================= sa-name: ospf1 key-Mode: manual Encap protocol: ESP SPI Value: 9 Encrypt Algorithm: 3dec-cbc Encrypt-key: 52fb29f723b0800870dc83e3 Encrypt-key-Len: 24 Auth Algorithm: hmac-md5 Auth-key: 123456789abcdef0 Auth-key-Len: 16 Mode: transport Lifetime-Sec: 1000 Lifetime-Byte: 20000 Switch:1#show ipsec sa name ospf1 ========================================================================= IPSEC Security Association Table ========================================================================= sa-name: ospf1 key-Mode: manual Encap protocol: ESP SPI Value: 9 Encrypt Algorithm: 3dec-cbc Encrypt-key: 52fb29f723b0800870dc83e3 Encrypt-key-Len: 24 Auth Algorithm: hmac-md5 Auth-key: 123456789abcdef0 Auth-key-Len: 16 Mode: transport Lifetime-Sec: 1000 Lifetime-Byte: 20000 Switch:1#show ipsec sa-policy ========================================================================= SA POLICY TABLE ========================================================================= Policy Name Security Association ------------------------------------------------------------------------- ospf1 ospf1 -------------------------------------------------------------------------
The following table defines parameters for the show ipsec sa command.
Variable |
Value |
all |
Displays all security associations. |
name WORD<1–32> |
Displays a specific security association based on name. |
Use the data in the following table to use the show ipsec command.
Variable |
Value |
sa-policy |
Displays all security associations linked to a specific policy. |
