Use the port shortcut menu
Perform this procedure to display the port shortcut menu.
  1. In the Device Physical View, select a port.
  2. Right-click the selected port.
Port shortcut menu field descriptions
Use the data in the following table to use the port shortcut menu.
Name
Description
Edit General
Configures the general options for the port.
Edit IP
Configures the IP options for the port.
Edit IPv6
Configures the IPv6 options for the port.
Channelization Enable
Enables channelization for the port.
Channelization Disable
Disables channelization for the port.
Graph
Displays the statistics for the port.
Enable
Enables the port.
Disable
Disables the port.
