  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the MACSec MKA Profile tab.
  4. Select Insert.
  5. For Id, type an MKA ID value.
  6. For Name, type the profile name.
  7. Optional: Select ReplayProtectEnable to enable replay protect.
  8. Optional: For ReplayProtectWindow, type a value for the replay protect window size.
  9. Optional: From the OffsetValue options, select a level for confidentiality offset.
  10. Select IncludeSCIEnable to enable the SCI field in MACsec frames.
  11. Select Insert.
MACSec MKA Profile Field Descriptions
Use the data in the following table to use the MACSec MKA Profile tab.
Name
Description
Id
Specifies a unique identification number for an MKA profile.
Name
Specifies the profile name.
ReplayProtectEnable
Specifies whether replay protect is enabled. The default is disabled.
ReplayProtectWindow
Specifies the maximum acceptable difference in packet ID numbers between out of order packets. If a packet ID number differs from the ID number of the previously received packet by more than the specified window size, it is dropped.
OffsetValue
Specifies the number of bytes after the Ethernet header from which data encryption begins. The default is no offset.
PortMembers
Specifies the ports that are members of an MKA profile.
IncludeSCIEnable
Note: Exception: only supported on VSP 8400 Series, and VSP 4900 Series.
Specifies whether SCI tagging is enabled for a MACsec-enabled switch. The default is disabled.
