Use Virtual Router and Forwarding (VRF) Lite to provide many virtual routers using one switch.
This section shows you how to configure a VRF instance and how to associate ports and VLANs with VRF instances.
The following task flow shows you the sequence of procedures you perform to configure VRF Lite.
