Use this procedure to monitor IPv6 multicast route statistics at regular intervals.
  1. Enter Privileged EXEC mode:
    enable
  2. Monitor IPv6 multicast route statistics:
    monitor ipv6 mroute stats WORD<7-400> {Ipv6address[,Ipv6address][,...]}
    You can monitor a maximum of 10 group IP addresses.
Example:
Monitor the IPv6 multicast route statistics for the group IPv6 address FF05::1. In this example, the statistics are monitored at intervals of 5 seconds for a duration of 300 seconds.
The output from monitoring three consecutive intervals is displayed below.
Switch:1>enable
Switch:1#monitor IPv6 mroute stats FF05::1
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 16:54:25 2015
                         Multicast Stats - GlobalRouter
GroupAddress               SourceCounter      IngressPackets       IngressBytes   AverageSize
ff05:0:0:0:0:0:0:1         1                  2446250              2935500000    1200
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 16:54:31 2015
ff05:0:0:0:0:0:0:1         1                  2448947              2938736400    1200
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 16:54:37 2015
ff05:0:0:0:0:0:0:1        1                  2452185              2942622000    1200
Switch:1#
Monitor the IPv6 multicast route statistics for a maximum of 10 group IPv6 addresses. The statistics are monitored at intervals of 5 seconds for a duration of 300 seconds.
Switch:1#monitor IPv6 mroute stats FF05::1,FF05::2,FF05::3,FF05::4,FF05::5,FF05::6,FF05::7,FF05::8,FF05::9,FF05::a
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 17:04:55 2015
ff05:0:0:0:0:0:0:1       1                  2768926              3322711200    1200
ff05:0:0:0:0:0:0:2       1                  2768925              3322710000    1200
ff05:0:0:0:0:0:0:3       1                  2768925              3322710000    1200
ff05:0:0:0:0:0:0:4       1                  2768925              3322710000    1200
ff05:0:0:0:0:0:0:5       1                  2768925              3322710000    1200
ff05:0:0:0:0:0:0:6       1                  2768923              3322707600    1200
ff05:0:0:0:0:0:0:7       1                  2768923              3322707600    1200
ff05:0:0:0:0:0:0:8       1                  2768923              3322707600    1200
ff05:0:0:0:0:0:0:9       1                  2768923              3322707600    1200
ff05:0:0:0:0:0:0:a       1                  2768923              3322707600    1200
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 17:05:01 2015
ff05:0:0:0:0:0:0:1       1                  2771625              3325950000    1200
ff05:0:0:0:0:0:0:2       1                  2771625              3325950000    1200
ff05:0:0:0:0:0:0:3       1                  2771625              3325950000    1200
ff05:0:0:0:0:0:0:4       1                  2771624              3325948800    1200
ff05:0:0:0:0:0:0:5       1                  2771624              3325948800    1200
ff05:0:0:0:0:0:0:6       1                  2771622              3325946400    1200
ff05:0:0:0:0:0:0:7       1                  2771622              3325946400    1200
ff05:0:0:0:0:0:0:8       1                  2771622              3325946400    1200
ff05:0:0:0:0:0:0:9       1                  2771622              3325946400    1200
ff05:0:0:0:0:0:0:a       1                  2771622              3325946400    1200
                         MULTICAST STATISTIC
Monitor Interval: 5sec | Monitor Duration: 300sec       Tue Dec 22 17:05:07 2015
ff05:0:0:0:0:0:0:1       1                  2774864              3329836800    1200
ff05:0:0:0:0:0:0:2       1                  2774863              3329835600    1200
ff05:0:0:0:0:0:0:3       1                  2774863              3329835600    1200
ff05:0:0:0:0:0:0:4       1                  2774863              3329835600    1200
ff05:0:0:0:0:0:0:5       1                  2774863              3329835600    1200
ff05:0:0:0:0:0:0:6       1                  2774861              3329833200    1200
ff05:0:0:0:0:0:0:7       1                  2774861              3329833200    1200
ff05:0:0:0:0:0:0:8       1                  2774861              3329833200    1200
ff05:0:0:0:0:0:0:9       1                  2774861              3329833200    1200
ff05:0:0:0:0:0:0:a       1                  2774861              3329833200    1200
Switch:1#
Variable definitions
Use the data in the following table to use the monitor ipv6 mroute stats command:
Variable
Definition
Specifies the multicast group IP address for which to monitor statistics.
The group IP address is in one of the following formats: a single IP address or a series of IP addresses, up to a maximum of 10.
