Enable the remote access service to provide multiple methods of remote access.
File Transfer Protocol (FTP), Trivial File Transfer Protocol (TFTP) and Telnet server support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
    enable
    configure terminal
  2. Enable the access service:
    boot config flags {ftpd | sshd | telnetd | tftpd}
  3. Repeat as necessary to activate the desired services.
  4. Save the configuration.
Enable the access service for Telnet:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#boot config flags telnetd
The following table defines remote access parameters for the boot config flags command.
Variable
Value
ftpd
Activates or disables the FTP server on the switch. The default value is disabled. To enable FTP, ensure that the tftpd flag is disabled.
sshd
Activates or disables the SSHv2 server service. The default value is disabled.
telnetd
Activates or disables the Telnet server service. The default is disabled.
tftpd
Activates or disables Trivial File Transfer Protocol server service. The default value is disabled.
