Use this procedure to verify details of the LLDP neighbors learned.
The following example shows how two switches—an FA Server and an FA Proxy discover each other as LLDP neighbors.
Switch A, which is the FA Server is a VSP 7200 Series switch (model 7254XSQ) and switch B which is the proxy device is an ERS 4826GTS switch.
The following examples show neighbor discovery on non-channelized ports.
On the non-channelized port 1/1 on the FA Server, verify neighbor discovery of the proxy switch.
Switch:1>enable Switch:1#show lldp neighbor ========================================================================================== LLDP Neighbor ========================================================================================== Port: 1/1 Index : 1 Time: 1 day(s), 04:03:52 ChassisId: MAC Address 70:30:18:5a:05:00 PortId : MAC Address 70:30:18:5a:05:07 SysName : SysCap : Br / Br PortDescr: Port 7 SysDescr : Ethernet Routing Switch 4826GTS HW:10 FW:5.8.0.1 SW:v6.9.2.027 ------------------------------------------------------------------------------------------ Total Neighbors : 1 ------------------------------------------------------------------------------------------ Capabilities Legend: (Supported/Enabled) B= Bridge, D= DOCSIS, O= Other, R= Repeater, S= Station, T= Telephone, W= WLAN, r= Router Switch:1(config)#
On the proxy switch, verify discovery of the FA Server switch.
Switch:1>enable Switch:1#show lldp neighbor ------------------------------------------------------------------------------- LLDP neighbor ------------------------------------------------------------------------------- Port: 7 Index: 71 Time: 12 days, 21:40:30 ChassisId: MAC address a4:25:1b:52:70:00 PortId: MAC address a4:25:1b:52:70:04 SysName: BEB1-7254XSQ SysCap: rB / rB (Supported/Enabled) PortDesc: Virtual Services Platform 7254XSQ - Gbic1000BaseT Port 1/1 SysDescr: VSP-7254XSQ (6.0.0.0_GA) ------------------------------------------------------------------------------- Sys capability: O-Other; R-Repeater; B-Bridge; W-WLAN accesspoint; r-Router; T-Telephone; D-DOCSIS cable device; S-Station only. Total neighbors: 1
The following examples show neighbor discovery on channelized ports (if your platform supports channelization).
On the channelized port 1/1/1 on the FA Server switch, verify discovery of the proxy switch.
Switch:1>enable Switch:1#show lldp neighbor ========================================================================================== LLDP Neighbor ========================================================================================== Port: 1/1/1 Index : 1 Time: 1 day(s), 04:03:52 ChassisId: MAC Address 70:30:18:5a:05:00 PortId : MAC Address 70:30:18:5a:05:07 SysName : SysCap : Br / Br PortDescr: Port 7 SysDescr : FA Proxy 4826GTS HW:10 FW:5.8.0.1 SW:v5.9.2.027 ------------------------------------------------------------------------------------------ Total Neighbors : 1 ------------------------------------------------------------------------------------------ Capabilities Legend: (Supported/Enabled) B= Bridge, D= DOCSIS, O= Other, R= Repeater, S= Station, T= Telephone, W= WLAN, r= Router Switch:1(config)#
Verify neighbor discovery on the proxy switch.
Switch:1>enable Switch:1#show lldp neighbor ------------------------------------------------------------------------------- LLDP neighbor ------------------------------------------------------------------------------- Port: 7 Index: 71 Time: 12 days, 21:40:30 ChassisId: MAC address a4:25:1b:52:70:00 PortId: MAC address a4:25:1b:52:70:04 SysName: BEB1-7254XSQ SysCap: rB / rB (Supported/Enabled) PortDesc: Virtual Services Platform 7254XSQ - 40GbCR4-Channel Port 1/1/1 SysDescr: VSP-7254XSQ (6.0.0.0_GA) ------------------------------------------------------------------------------- Sys capability: O-Other; R-Repeater; B-Bridge; W-WLAN accesspoint; r-Router; T-Telephone; D-DOCSIS cable device; S-Station only. Total neighbors: 1
The following table defines parameters for the show lldp neighbor command.
Variable |
Value |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. Displays LLDP neighbor information on the specified port. |
