Enable Equal Cost MultiPath (ECMP) to permit routers to determine up to eight equal-cost paths to the same destination prefix. You can use the multiple paths for load-sharing of traffic, which provides fast convergence to alternative paths. By maximizing load sharing among equal-cost paths, you can maximize the efficiency of links between routers.
To configure ECMP for a VRF instance, after you enable ECMP globally, use VRF Router Configuration mode rather than Global Configuration mode.
Different hardware platforms can support a different number of ECMP paths. For more information, see VOSS Release Notes.
    enable
    configure terminal
  2. Enable ECMP globally:
    ip ecmp
  3. Optional: Configure the maximum number of ECMP paths:
    ip ecmp max-path <ECMP-Paths>
  4. Optional: Configure a prefix-list for the target destination:
    ip prefix-list WORD<1-64> <A.B.C.D/X> [ge <0-32>] [le <0-32>]
  5. Optional: Configure an ECMP pathlist to specify routes with the required number of paths:
    ip ecmp pathlist-<1-8> WORD<1-64>
  6. Optional: Return to Privileged EXEC mode:
    end
  7. Optional: Apply changes to all ECMP pathlist configurations:
    ip ecmp pathlist-apply [vrf WORD<1-16>]
Define which IP prefixes use ECMP and which do not.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#ip ecmp
Switch:1(config)#ip prefix-list ecmpAllowed 192.0.2.0/24 ge 24 le 24
Switch:1(config)#ip prefix-list ecmpDenied 0.0.0.0/0 ge 0 le 32
Switch:1(config)#ip ecmp pathlist-2 ecmpAllowed
Switch:1(config)#ip ecmp pathlist-1 ecmpDenied
Switch:1(config)#end
Switch:1#ip ecmp pathlist-apply
The following table defines parameters for the ip ecmp command.
Variable
Value
Specifies the maximum number of ECMP paths. Different hardware platforms can support a different number of ECMP paths. For more information on the maximum number of ECMP paths supported on the switch, see the scaling information in VOSS Release Notes.
pathlist-1 WORD<0-64>
Specifies one equal-cost path to the same destination prefix. To remove the policy, enter a blank string.
pathlist-2 WORD<0-64>
Specifies up to two equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-3 WORD<0-64>
Specifies up to three equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-4 WORD<0-64>
Specifies up to four equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-5 WORD<0-64>
Specifies up to five equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-6 WORD<0-64>
Specifies up to six equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-7 WORD<0-64>
Specifies up to seven equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
pathlist-8 WORD<0-64>
Specifies up to eight equal-cost paths to the same destination prefix. To remove the policy, enter a blank string.
Applies the pathlist configuration changes. You can optionally specify a VRF name.
The following table defines parameters for the ip prefix-list command.
Variable
Value
WORD<0-64>
Specifies the prefix list name.
<A.B.C.D/X>
Specifies the IP address and network mask in one of the following formats:
  • a.b.c.d/x
  • a.b.c.d/x.x.x.x
  • default
ge <0-32>
Specifies the minimum length to match. Lower bound and higher bound mask lengths together can define a range of networks.
le <0-32>
Specifies the maximum length to match. Lower bound and higher bound mask lengths together can define a range of networks.
