Configure Power to Module Slots
Use this procedure to control whether to supply power to specific slots. By default, power is available to all slots.
This procedure only applies to VSP 8400 Series.
The following table defines parameters for the sys power slot command.
Variable |
Value |
{slot[-slot][,...]} |
Identifies the slot in one of the following formats: a single slot (1), a range of slots (1–3), or a series of slots (1,2,4). The default is to provide power to all slots. |
