In SPBM, each node has a System ID, which also serves as Backbone MAC address (B-MAC) of the switch. The system populates these Backbone MAC addresses into the SPBM VLAN Forwarding Information Base (FIB). When the system discovers a network topology and stores it in the IS-IS link-state database, each node calculates shortest path trees for each source node, so that a unicast path now exists from every node to every other node. With this information, each node populates unicast information that it receives from SPBM into the FIB for forwarding purposes.
I-SIDs are only used for virtual services (Layer 2 VSNs and Layer 3 VSNs). If you only enable IP Shortcuts on the Backbone Edge Bridges, I-SIDs are never exchanged in the network as IP Shortcuts allows for Global Routing Table (GRT) IP networks to be transported across IS-IS.
The system adds the routes within the same VSN to the LSDB with a default preference of 7 and the inter-VSN routes with a route preference of 200. With IS-IS accept policies you can change the route preference for incoming routes. If the system learns the same route from multiple sources with different route preferences, then the routes are not equal cost multipath (ECMP) routes. The system prefers the route with the lowest route preference. In Layer 2, if there is a tie-break between routes from multiple sources, the tie-breaking is based on cost and hop count.
Perform this procedure to display the remote IP unicast FIB. You can view the IP routes from remote Backbone Edge Bridges (BEBs)
- Select SPBM Remote.
- Select the IP Unicast FIB tab.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
IP Unicast FIB Field Descriptions
Use the data in the following table to use the IP Unicast FIB tab.
Name |
Description |
VrfId |
Specifies the VRF ID of the remote IP unicast FIB entry, 0 indicates NRE. |
DestinationIpAddrType |
Specifies the address type of the destination IP address. |
DestinationIpAddr |
Specifies the destination IP Address of the remote IP unicast FIB entry. |
DestinationMask |
Specifies the destination IP mask of the remote IP unicast FIB entry |
NextHopBmac |
Specifies the nexthop B-MAC of the remote IP unicast FIB entry. |
DestIsid |
Specifies the destination I-SID of the remote IP unicast FIB entry. |
Vlan |
Specifies the VLAN of the remote IP unicast FIB entry. |
Isid |
Specifies the I-SID of the remote IP unicast FIB entry. |
NextHopName |
Specifies the nexthop hostname of the remote IP unicast FIB entry. |
OutgoingPort |
Specifies the outgoing port of the remote IP unicast FIB entry. |
PrefixCost |
Specifies the prefix cost of the remote IP unicast FIB entry. |
SpbmCost |
Specifies the B-MAC cost of the remote IP unicast FIB entry. |
Preference |
Specifies the IP Route preference of the remote IP unicast FIB entry |
MetricType |
Specifies the IP Metric Type of the remote IP unicast FIB entry. |
