You must create a Management Instance to gain access to specific management applications.
The Management Instance supports different management interface types. When you create the Management Instance, you specify the interface type and the switch automatically creates the appropriate instance ID for that type.
In a Layer 2 routing deployment, use a management VLAN. In a Layer 3 routing or Fabric deployment, use a management CLIP. To separate management network from Layer 2 and Layer 3, use a management OOB.
Each Management Instance supports a IPv4 and IPv6 (global scope) management address for use by management applications.
Interface Field Descriptions
Use the data in the following table to use the Interface tab.
Name |
Description |
InstanceId |
Indicates the Management Instance type associated with this entry. |
InterfaceType |
Indicates the interface type. |
VlanId |
Specifies the VLAN ID to associate with the management VLAN. |
OOBIfindex |
Specifies the interface ID to associate with the management OOB. |
VrfName |
Specifies the VRF name to associate with the management CLIP . |
State |
Indicates if the interface is enabled for this instance. The default is disabled. |
InterfaceMacAddr |
Indicates the MAC address for the interface. |
InterfaceName |
Indicates the interface name. |
InterfaceTopologyIpFlag |
Specifies if the interface is the default topology source IP. |
ZtpOn |
Identifies the Zero Touch Provisioning status for the interface. |
RmonAdminEnable |
Specifies if RMON is administrative enabled for the interface. |
RmonOperEnable |
Indicates the RMON operational status for the interface. |
RmonIpAddress |
Indicates the RMON IP address for the interface. |
MacOffset |
Translates the IP address into a MAC address. |
| DropIcmpFragEnable Note: Exception: Not supported on XA1400
Series.
Enables IPv4 Fragmented ICMP packet filtering on the Management Instance. The default is disabled. |
| DropIcmpv6FragEnable Note: Exception: Not supported on XA1400
Series.
Enables IPv6 Fragmented ICMP packet filtering on the Management Instance. The default is disabled. |
Isid |
Specifies the I-SID number that associated with the Management Instance VLAN for the DvR Leaf node. For non DvR node, the default I-SID value is 0 and this value cannot be edited. |
