Use Inter-VSN routing to route between IP networks on Layer 2 VLANs with different
I-SIDs. Inter-VSN routing is typically used only to extend a VLAN as a Layer 2 Virtual
Services Network (VSN) for applications such as vMotion. Use IP Shortcuts or Layer 3
VSNs to route traffic. You must configure both the Backbone Edge Bridges (BEBs) and the
Backbone Core Bridge (BCB).
To enable inter-VSN routing, you must configure the IP interface where the routing
instance exists.
You must configure the required SPBM and IS-IS infrastructure.
Follow these steps on the BEBs that contain the VSNs you want to route traffic
between.
Create a customer VLAN (C-VLAN)
by port and add ports in the C-VLAN:
In the navigation pane, expand .
Select VLANs.
On the Basic tab, select Insert.
For Id, type an unused VLAN ID, or use the ID
provided.
For Name, type the VLAN name, or use the name
provided.
For Color
Identifier, select a color from the list, or use the
color provided.
For Type, select byPort.
For PortMembers, select the ellipsis (...).
Select the ports to add as member ports.
The ports that are selected are recessed, while the nonselected ports
are not recessed. Port numbers that are dimmed cannot be selected as
VLAN port members.
Select OK.
Select Insert.
Map a C-VLAN to an I-SID:
From the same navigation path, select the Advanced
tab.
For Isid, specify the I-SID to associate with the specified
VLAN.
The switch reserves I-SID 0x00ffffff. The switch uses this I-SID to
advertise the virtual B-MAC in a SMLT dual-homing environment. The
platform clears the receive and transmit bit of this I-SID,
therefore I-SID 0x00ffffff cannot be used for any other service.
Select Apply.
Important
When a protocol VLAN is created, all ports are added to the VLAN
including SPBM ports. To configure a protocol-based VLAN as a
C-VLAN, you must first remove the SPBM-enabled ports from the
protocol based VLAN, and then configure the protocol-based VLAN
as a C-VLAN.
Configure the Backbone Core
Bridge (BCB) for Inter-VSN Routing. For more information, see Configure BCBs for Inter-VSN Routing.
