Perform this procedure to configure the additional addresses for which the virtual router acts as a back up.
  • Assign an IPv6 address to the interface.
  • Enable routing globally.
  1. In the navigation pane, expand the following folders: Configuration > Edit > Port.
  2. Click IPv6.
  3. Click the VRRP tab.
  4. Click AssociatedIPAddr.
  5. Click Insert.
  6. Type the address.
  7. Type the prefix length.
  8. Click Insert.
